Author Topic: Battery advice - need help choosing between two  (Read 23435 times)
Re: Battery advice - need help choosing between two
« Reply #15 on: February 02, 2018, 02:43:50 PM »
I think this is the one I'm going to go with.  It's on the "approved" listing and the Ah in the description seems to fall right in line with my battery's Ah.
https://www.amazon.com/CTEK-56-353-12-Volt-Battery-Charger/dp/B000FRLO9Y/ref=sr_1_fkmr0_1?ie=UTF8&qid=1517611120&sr=8-1-fkmr0&keywords=c-tek+mus+7002
« Reply #16 on: February 02, 2018, 02:52:08 PM »
the Northstar doesnt need it but I do it just because it can't hurt.  Northstar uses the same thin plate technology as odyssey but supposedly they do not need the higher voltage like the odyssey.
Rick I have that exact charger because it has all the features I wanted, the output isn't as high as I wanted but it does the job.
« Last Edit: February 02, 2018, 02:56:49 PM by knightrider »
« Reply #17 on: February 02, 2018, 03:05:22 PM »
Perfect, thanks for the input.  I've been looking at stupid chargers for hours, my typical over-thinking of things.
« Reply #18 on: February 02, 2018, 04:48:45 PM »
Celt - go with the one I bought from Batteries Plus - the same one knight rider recommended. It's freaking awesome for the price, and has a much larger capacity than the stock size. Drops right in, no modifications necessary, and the battery terminals fit with no modifications too. Plus, a 60 month warranty at all Batteries Plus locations nationwide. You really can't go wrong.
knight rider - are you saying that you still top off your Northstar knock-off? I figured I didn't need to do that now that I stepped away from Odyssey. Maybe I should be looking at investing in a charger too.   :-[
  I'm going to check that out and see what to do. I do like that 60 month warranty and it has good CCA's. I just want to make sure it can stand up to running the fridge and winch and be able to bounce back. Maybe you and Knightrider can chime in a little about their performance over time and use.
« Reply #19 on: February 02, 2018, 06:29:48 PM »
mine has been great so far, I left my fridge on fast freeze for about 18 hrs before the last trip so it made some 1 gallon ice cubes and still started the truck no problem the next day.  I put it on charge overnight after that just to bring it back to 100% before leaving.  I also used my winch to drag my truck over some rocks on a trip to coyote flats with Jeffbett and Steve with no issues.
« Reply #20 on: February 02, 2018, 08:01:25 PM »
  It sounds like you and Joe really have some great things to say about those batteries. I've been doing some research for them but like to get opinions from guys I know. I appreciate all the feedback!
« Reply #21 on: February 03, 2018, 12:12:36 AM »
When Jordan guinea pigs a product and actually talks about it positively, you know it's good.
Usually, he "recommends" something for me to buy, I use it, then he considers the results.
We have about a 90% success rate so far so I don't feel too bad.
Eric, did you ever end up with solar?  I can't remember.
« Reply #22 on: February 03, 2018, 12:19:42 AM »
As an aside, I have the 3110 pc whatever Odyssey group 31 monster battery.
I also have some diehard battery charger thing that Jordan recommended me to get on the ebay.
The ONLY time I had a problem was when I left my fridge plugged in for 6 days while parked at the airport.  It was early and I totally forgot to unplug it before i left. I had to have the airport parking lot dude give me a jump..
It was a group effort between my stupidity and the edgestar not shutting off at the right voltage.  ($300 fridge vs $1,200 fridge BTW edgestar vs. arb)
I have had the battery for a while, maybe 18 months to two years and I've only ever topped it off after that airport incident.
Maybe it will die soon, I have no idea, but it's performing great for me so far.
« Reply #23 on: February 03, 2018, 04:25:14 AM »
  Yep, I run the solar panel if I'm going to be parked for more than a day. I just think that over the last few years of a lot of winching, refrigerator and heavy air compressor use beat the existing battery up. I'm still happy with Interstate but wanted to explore other options as it sounds like this may be one of the better ones. Thanks for the input!
« Reply #24 on: February 07, 2018, 08:15:00 AM »
So, I received the CTEK charger yesterday, broke it out of the box, hooked it up to start charging, and the charger wouldn't power on.  I guess I should've tried plugging it in, first.  I tried multiple outlets with not luck.  Back it goes. Hopefully, then next one won't have problems.
« Reply #25 on: February 07, 2018, 10:29:07 AM »
That's a bummer, you should get 2 lights when you plug it into the wall, the power led and one of the charge profile led next to the power led.
You didn't happen to attach it to the battery first then the wall?  I always plug it into the wall first, not sure if that matters with the Ctek.
« Reply #26 on: February 07, 2018, 10:55:32 AM »
I initially attached it to the battery first, old habit from the battery tender I use on the motorcycle.  When this didn't work I went to the wall, then the battery.  When this also didn't work, I just moved around to different wall outlets and the thing still wouldn't power on.  Oh well, Amazon is good about returns and I already have another on the way.
« Reply #27 on: February 08, 2018, 05:48:16 PM »
Fun fact, the GFI circuit was tripped in the garage. I think I sent back a perfectly good charger. Lol That's what I get for not checking it in the house.
« Reply #28 on: February 08, 2018, 05:59:57 PM »
 :D   :)
 :D
« Reply #29 on: February 08, 2018, 08:11:49 PM »
doh
