Author Topic: Battery advice - need help choosing between two  (Read 23430 times)
Re: Battery advice - need help choosing between two
« Reply #30 on: February 08, 2018, 08:56:36 PM »
doh
I used many words far worse than that.
« Reply #31 on: February 09, 2018, 08:42:26 AM »
Okay, my idiocy aside, I hooked up the new charger last night.  Everything seems to have gone smoothly.  I do need a multi-meter to actually see where the battery is before and after charge.  However, the charger only went through the bulk phase for about 1.5 hours.  This tells me the battery wasn't too low.  The CTEK is definitely a good option over paying $180 for the Odyssey brand charger.
« Reply #32 on: February 09, 2018, 08:54:11 AM »
Yea it doesn't take long because the battery was probably around 80-90% and the ctek is a very efficient charger, it holds the amperage higher, for longer resulting in a faster charge than other chargers I tested.  I still usually let it trickle charge overnight.  resting voltage for 100% on the odyssey is 12.85v
« Last Edit: February 09, 2018, 08:57:02 AM by knightrider »
« Reply #33 on: February 09, 2018, 10:45:20 AM »
Yep, I left it on overnight.  I actually like this charger better than the Battery Tender I use for the motorcycle.  I'll probably use the CTEK on the bike battery now.  I'm also going to hook up the wife's car, as I put a different brand AGM in there a couple of months ago.
