Author Topic: Building a Trailside Repair Kit???  (Read 12412 times)
Lava
  • 4wd Pts: 21
« on: January 27, 2014, 11:24:06 AM »
Ive got a bunch of tools and spares in my X for that just in case moment on an outing.
I would like to collect a standardized list of what size tools and sockets are needed at a minimum to be able to fix the X on a trail run and am looking for input. That way members can come to this list and see what they need as a start. As you reply, I'll add it to the list below.
This list is in no way the definitive list. Just a good place to start collecting,  and a minimum to get you off the trail to the appropriate repair service or Tow truck.  ::)
Wrench sizes:
8mm
10mm
12mm
14mm
17mm
18mm
19mm
21mm (suspension/tie rod)
22mm (suspension/tie rod)
Socket Sizes:
10mm reg/deep
17mm reg/deep
18mm reg/deep
19mm reg/deep
21mm reg/deep. (Suspension/tie rod)
22mm reg/deep (suspension/tie rod)
32mm reg (axle nut, Ball joint nut on SPC UCA's)
Hand tools:
Small 1/4" drive socket set with sae/met sizes
Mini sledge Hammer
Deadblow Hammer
Crescent or Adjustable Wrench
Phillips and Flathead Screw drivers, long and short handle
Screwdriver set with numerous tip sizes and security bits
Strap wrench
Breaker bar
Hack Saw
Tin snips
Spanner wrench for coilovers
Vice Grips
Slipjaw pliers
Needle nose pliers
Snap ring pliers
Air tools
Misc.:
Duct Tape
Electric Tape
Self Sealing Hose tape
Cable ties (Tie Wraps)
Spare Fuses
Voltmeter
Matching Spare nuts and bolts in various lengths
Sheet Metal Screws
Movers blanket for laying on while working on X
Tire Irons
Spare valve caps
Tire patch/plug kit (can of tire slime)
Gas/fluid siphon Hose
2 party epoxy for plastic/metal (JB Weld)
Spare roll of electric wire
Assorted solderless connectors
Rechargeable flashlight or headlamp
Tie Wire (metal bailing wire)
Ratchet Strap
550 or 770 cord (Christians Shoelaces)
Assorted Cotter Pins
Small WD40 can
Packets of Red Grease / Lithium Grease
Spare Oil and brake fluid
Blue Loctite
Hi-lift Slider Adapter
Hi-lift style Jack
Small torch
Telescopic Magnet (for when you drop the nut in a place you cant get your hands)
SWR Meter
Funnel for fluids
12v Air Compressor
Small tube cutter
1 Ft sections of steel tube (think Brake hardlines)
Compression fittings for the hardlines
Teflon Tape
Pre cut shrink tube / lighter to shrink the tube
Solder / Soldering pencil
Spare 50amp Winch Fuses
Universal Battery Post cable clamp
Spare Flat Ground Strap
Smal 4ft x 4ft section of clear Plastic sheet (think broken window/rain)
Metal coat Hanger
Hitch mounted Vise
2ft sections 1/2", 5/8", 3/4" sections of rubber hose
Hose clamps and Barbed hose connectors
Exhaust repair clamp
Code Reader
Spare Parts:
CV Joint
Front Driveline Axle (half axle)
Axle Nut
Ball joint boot
Rubber Shock Boot
Oil filter / Air Filter
Universal Joint w/ clips
Spark Plug or two "pre-gapped"
A few Lug Nuts
Serpentine Belt
Radiator Hose
Tie Rods
Belt Tensioner
« Last Edit: January 29, 2014, 03:54:08 AM by Lava »
My other vehicle is an X-WING
Justin - KK6JEC
Re: Building a Trailside Repair Kit???
« Reply #1 on: January 27, 2014, 12:51:13 PM »
Hack saw
tie wraps
tie wire
tin snips
You thought of a lot of things that I hadn't ;)
Thanks, this is a good idea
« Reply #2 on: January 27, 2014, 01:13:22 PM »
Great idea....here's what I came up with...
file these under misc.
-body bag
-business card of a good lawyer (1-800-BETTER CALL SAUL)
-spork
-$9 in quarters
-extra shoelaces
-spare plutonium for the flux capacitor
Lava
  • 4wd Pts: 21
« Reply #3 on: January 27, 2014, 01:15:21 PM »
Funny. Except maybe the shoe laces, how can you fix your X on the trail with the remainder of your list?  ;)
Justin - KK6JEC
« Reply #4 on: January 27, 2014, 02:18:00 PM »
Slider adapter for hi lift
« Reply #5 on: January 27, 2014, 02:20:04 PM »
21 & 22 mm sockets for suspension and tie rod repair.
32 mm axle nut socket
Loc tite blue
12mm and 14mm wrenches
BikersCage
« Reply #6 on: January 27, 2014, 02:53:36 PM »
Beer...
I was going to say hacksaw, but then i found it pretty good list.
Might have to start putting together some of these smaller items in some sort of go bag.
In the military ground style guys have a go bag...  Normally carries 3 days worth of supplies, basically a larger backpack.  For all the items not normally on the x it would likely fit in there!
Blackx
  • 4wd Pts: 16
« Reply #7 on: January 27, 2014, 03:11:05 PM »
I find vise grips important.
Jeff
Crawler News
« Reply #8 on: January 27, 2014, 04:01:30 PM »
21 and 22 box end wrenches, one of those extendable magnets, slipjaw plyers, needlenose plyers
« Reply #9 on: January 27, 2014, 04:07:28 PM »
A small torch
Lava
  • 4wd Pts: 21
« Reply #10 on: January 27, 2014, 08:46:06 PM »
These are all great suggestions!  ;D ;D
Can anyone provide information as to what parts on the X coincide with what size wrench or socket? I'll add them to the list to be sure we cover all the necessary parts.. ???
Justin - KK6JEC
« Reply #11 on: January 27, 2014, 09:49:35 PM »
Along with a crap load of stuff.
   I carry a set of
1/4 sockets
1/4 deep sockets
3/8 sockets
3/8 deep sockets
A set of box wrenches
All metric. You never know what youll need. From battery terminals, to shock mounts and axel nuts.
I also carry a serpentine belt, tensioner, radiator hose, tie rods, a half axel, air tools and not your everyday computer reader.
« Reply #12 on: January 28, 2014, 12:19:44 AM »
I also carry standard wrenches and sockets in a separate bag to fix heeps and fords,
Sent from my Galaxy Nexus using Tapatalk
« Reply #13 on: January 28, 2014, 04:29:00 PM »
8mm wrench and socket for the alternator ground screw and ignition stuff, variety of different STYLE of wrenches, extra cb radio antenna, extra FRS walkie talkie or battery, a forehead light, extra batteries for flashlights.  From the autoparts store HELP! section, i carry a fuel, universal hose and a radiator hose repair/splice kit, a grab-bag of bungee cords,
« Reply #14 on: January 28, 2014, 09:05:14 PM »
Throw in a couple ratchet straps.  They can be used from broken motor mounts, broken leaf spring centerbolts, re-inflating a blown bead in a tire.  Need I go on?
