Author Topic: Do we have any opinions on D-ring tow hitches?  (Read 17218 times)
Re: Do we have any opinions on D-ring tow hitches?
« Reply #15 on: December 31, 2015, 12:32:22 PM »
I have it in my car all the time.  So I can give it to you whenever meet up
Sent from my SM-G920V using Tapatalk
ManduhO
    • 2014 X
« Reply #16 on: December 31, 2015, 01:28:24 PM »
Nice! Thanks again  :D
« Reply #17 on: February 22, 2016, 03:23:00 PM »
What is a good brand of D-Ring to keep on hand, as well as straps? I'd like to have them just in case.
« Reply #18 on: February 22, 2016, 06:02:30 PM »
There are many brands of d-rings but I'd be willing to bet there are only a few manufacturers. Find one that'll fit the size of the hole where you're mounting it and make sure the weight rating is good for what you want to tow. I have an ARB snatch strap and a cheaper tow strap. The stretch in the OME should help with recovering someone that is stuck. The static strap will be good in a "normal" tow situation. I would also check out soft shackles, they come in handy. I was able to pull a car out of a ditch a few days ago and it did not have tow hooks. I was able use the shackles to find a safe spot to pull the car.
« Last Edit: February 22, 2016, 06:06:43 PM by RikRong »
« Reply #19 on: February 23, 2016, 11:55:40 AM »
just a word to the wise.
I would not mount the D-rings to ride in a semi-permanent position.   Why?   First of all if you tighten the pins tightly enough to keep from vibrating loose and falling off.  You will find yourself running around trying to find something to remove the pin to put the D-ring through the loop. Never a good thing to do at all the wrong times.
What I do is keep my D-rings along with my straps in the wet-box up top of my X.  Instantly accessed and ready to install on my front bumper (If I don't use my winch).   As Danny mentioned this is where my hook comes into play on the rear.   I have found that the hook provides an instant attachment for the strap on the rear of my rig.   On other great side benefit, as Erik mentioned,   it is a great guard for the spare tire and bumper on serious departure angle situations.   That hook will take a lot of abuse that before those rocks ever get to the bumper or spare.
A little picture to show that a hook is very valuable in split second situations:
http://i1361.photobucket.com/albums/r672/SocalX/IMG_7182_zpsdvtzrm5e.jpg
« Reply #20 on: February 23, 2016, 01:04:25 PM »
Great information guys, I had read somewhere else about not having it permanently mounted as well, totally makes sense.
Riz98
  • 4wd Pts: 8
  • PBR ASAP
    • 2002 Nissan Xterra
« Reply #21 on: February 24, 2016, 10:43:11 AM »
A couple weeks ago a Ford Raptor was stuck in the snow sitting on his frame a little.  It wasnt too bad and I tried to pull him out.  Long story short both bolts that were holding the tow hook onto the front frame sheared off and the hook went flying down the road.  It happened so quickly I wasnt sure what happened at first until I got out and the strap was just sitting in the road.  SO lucky nobody got hurt.  I was able to find the tow hook on the road about 200 yards away. The bolts were grade 8.  Not too sure I'll be pulling random people out anymore out anymore.
« Reply #22 on: February 25, 2016, 10:04:58 AM »
Did you flag your strap line?
Riz98
  • 4wd Pts: 8
  • PBR ASAP
« Reply #23 on: February 25, 2016, 12:35:38 PM »
No I didn't.  I was going back to my vehicle for a mid day beer and the guy that was stuck was right next to me so I thought I would try and help.  The strap I was using didn't have any metal hooks.  The strap just feel to the ground and did't recoil when the hook bolts snapped.  What exactly does flagging the line do?  I have heard about doing it when winching but not for a strap recovery.
« Reply #24 on: February 25, 2016, 12:44:55 PM »
at 1:49 he explains it.
« Reply #25 on: February 25, 2016, 12:45:09 PM »
Flagging a strap will work exactly the same way as it does on a winch line.
« Reply #26 on: February 25, 2016, 06:15:35 PM »
sounds like in this instance flagging the strap wouldn't have really helped as the hook didn't stay with the strap.
« Reply #27 on: February 26, 2016, 02:28:21 PM »
This time...
Video nails it...er, flags it.
