Author Topic: OBA setup  (Read 22217 times)
OBA setup
« on: February 18, 2015, 10:05:51 PM »
I got bored over the weekend and decided to turn my portable compressor into an on board air setup. It's a tankless setup, but I figured it'll be easier to air up on the trail by simply flipping a switch and plugging the hose in. The compressor I have is the Harbor Freight one that typically goes on sale for $59.99. As far as cheap compressors go, this is right in line with the rest of them. It's a little bigger than the MV50 that a lot of people get (the little red one from Pep Boys, Amazon, etc) and I certainly don't expect it to last forever, but it airs my 32" tires up plenty quick and I've been pretty happy with it.
I needed a location to mount it - somewhere that it could get enough air to cool off, but also where it wouldn't be completely exposed to a ton of moisture. I ended up deciding on the space where the horns are mounted - behind the driver's side headlight between the back of the headlight housing and the stock air box. The compressor fits into this area well but requires removal of the headlight or airbox (or both) in order to be installed. I relocated the horns to the space between the airbox and driver's side fender (just below the inlet pipe for the stock airbox) and screwed the compressor baseplate down using self tapping screws. Two of the screws popped down into the fender well a little bit, but they were easily trimmed off.
My original plan was to mount a male air fitting to the rear bumper and allow the air to simply flow out of the fitting when the compressor is turned on but not connected to anything. I quickly realized that this would require an "always open" type of tire inflator, which is both hard to find and kind of a pain to deal with.
To remedy that situation, I decided that I need a pressure switch on the system to shut it off as soon as the lines are pressurized. I ordered one online and have yet to receive it in the mail (this is the only thing holding up the finished project at this point). With a pressure switch installed, I changed my design a little to use a female air connection instead, and decided to install one up front in addition to the one at the rear bumper.
I built a small manifold using two "t" adapters. The line from the compressor feeds into one "t", which will have the pressure switch connected to it and the second "t" connected to it as well. The second "t" has an air line running out to the front connection and another running to the back connection. The pressure switch runs to a relay that switches the compressor on and off, and I have the pressure switch wired up to an on/off switch inside the cabin. The pressure switch will shut the compressor off within a few seconds after being switched on, once the lines are pressurized to about 100 PSI. This way, I can turn the compressor on and it will switch itself off as I move from tire to tire, turning back on once I engage the trigger on the tire inflator. Here's a crude drawing of how the system is setup:
And here are some photos of the install so far. Like I said, I'm really just waiting on the pressure switch to arrive, so I can finish up the wiring and tighten down the clamps on the air lines.
Headlight removed to install the compressor:
Compressor mounted in it's final location:
View of the air line running from the compressor to the "t" fittings. I cut the funky chinese fitting end off of the Harbor Freight compressor's air hose and used a barbed 1/4" NPT fitting with a hose clamp in it's place. You can also see the front fitting mounted above the compressor. I used a metal "L" bracket and just screwed it to the back side of the radiator support under the hood. There is a 90* brass fitting under the "L" bracket, and a washer on either end of the bracket helping sandwich it all together:
A closer view of the "t" fittings and air lines. The black line is coming in from the compressor. The two clearish lines are running out to the front and rear connections on the vehicle. The last open port on the "t" fittings is for the pressure switch (it has a 1/4" to 1/8" reducer bushing installed, as the pressure switch has a 1/8" NPT thread on it):
A closer view of the front connection, which is mounted above the compressor. In this photo, the airbox is reinstalled, so you can see how everything fits together:
A view of the "t" fittings with the airbox reinstalled. I plan on using zip ties to simply attach these to some of the existing wire looms in the area, just to keep them from bouncing around and putting unnecessary fatigue on the air lines. I'll attach the lines down in a few places as well, I just need it all loose for now so I can get the pressure switch mounted once it arrives:
The rear connection mounted on the outside of the bumper. I opted for this spot just to the left of the license plate and kind of high up on the bumper so I won't kick it when I use the hitch as a step:
A view from the back of the bumper showing the rear air line attaching to the fitting. Just like on the front, I used a 90* elbow to route the line in the correct direction without putting too much stress on it. The 90* fitting has a washer sandwiched between it and the bumper, but there is no washer on the other side of the bumper where the female air connection is. This is because the metal on the bumper was much thicker than the "L" bracket I used up front, and there wasn't much threading poking through to attach the female connector to if I used the second washer:
Overall, I'm happy with how the system is coming out. The entire setup will have run me about $115 in the end. I spent about $50 on the compressor (used a 20% off coupon when it was already on sale for $59.99), $12 on a 25 foot 1/4" air line which I cut up for the project, about $25 at Lowes on the brass "t" fittings and 90* elbows and 1/4" to 1/8" reducer bushing, $8 on the pressure switch, about $10 for a relay and switch, and a few dollars on the female air fittings, the 1/4" NPT barbed air line fittings and the washers.
« Last Edit: February 18, 2015, 10:16:53 PM by JFanaselle »
Re: OBA setup
« Reply #1 on: February 18, 2015, 10:15:09 PM »
An onboard air system was by far one of the best and most versatile upgrades I ever did with my X. I only have one output connection though, interesting idea how you have two. I'd like to take a look at it on the Bradshaw run.
Re: OBA setup
« Reply #2 on: February 18, 2015, 10:19:13 PM »
I figure i'll probably use the one in the rear mostly. The coiled hose I have can reach all 4 tires when connected to the rear fitting, but it does put some pressure on the connection when I'm all the way up at the front (especially on the driver's side, since it's coming out of the rear bumper at about a 45* angle toward the passenger side and then bending back). I just figured it was easy to install the second one up front in case I ever need it.
Motorpig77
  • 4wd Pts: 31
Re: OBA setup
« Reply #3 on: February 19, 2015, 12:39:38 AM »
It looks good Joe! Nice job! Cant wait to see it in use on the Bradshaw Trail!
Re: OBA setup
« Reply #4 on: February 19, 2015, 07:59:35 AM »
Awesome job Joe, I was trying to figure out where to put OBA with stock bumper, now i have a new project lol
Re: OBA setup
« Reply #5 on: February 19, 2015, 08:25:49 AM »
That spot is exactly where my ARB compressor is mounted for my air locker...good choice!
Excellent garage engineering Joe   :)
Only concern that I see is dispersion of heat from the compressor head (the engine compartment is always a hot mess while you are driving) as running it to full inflation on four tires usually results in some high temps.
Re: OBA setup
« Reply #6 on: February 19, 2015, 09:11:01 AM »
Nice set up. I finally bought a compressor last week and am trying to figure out what to do with it in the future.
Re: OBA setup
« Reply #7 on: February 19, 2015, 10:13:54 AM »
one thing you are  going to want to do is get some caps for the female quick disconnects, they like to fill up with dirt.  im in the process of upgrading my OBA setup, my gf got me a new pump for valentines day so the puma pump is going away and an air zenith OB2 pump is taking its place, 200psi 5 gallon bomb under the truck :)
Re: OBA setup
« Reply #8 on: February 19, 2015, 02:15:58 PM »
Nice! Now that's a REAL Valentine's day gift right there! My wife is always wondering what kind of stuff to get me for Valentine's day, Anniversaries, Birthdays, etc, and I always tell her I want something for my Xterra. I FINALLY got a 40" LED bar for my birthday/father's day last year, so she's starting to get the hint.  :)
I figured those female air connections were going to get nasty fast. That's why I was originally going to install a male fitting on the bumper - I could always just turn the compressor on and blast any crap out of it if it were a male fitting. I will look into some kind of little plastic caps or something. I'm sure I can find something cheap on the interwebs. Not like they're very expensive to replace, but I don't want to be stuck on the trail one day unable to air back up (I guess that's another good reason to have the second connection under the hood as a backup). I suppose I better throw one into my tool-kit as a spare, just in case.
John - I am definitely worried about the heat situation. There just wasn't a good place to mount it where it wasn't going to get any heat at all. In addition to the confined space issue, it's also in position to get heated up a lot before ever needing it out on the trail. A day of wheeling in the desert during the summer will get that bad boy pretty warm before I ever even need it. I don't know if you noticed also, but two of the little head displacement fins are broken off of the heat sink on top of the piston housing (they broke off in the carrying bag a long time ago). So far, it hasn't gotten THAT hot when using it regularly, so I'm hoping that with the expected increase in heat now, it'll still be able to do my four 32" tires just fine before it shuts down. If not, I guess I'll be looking for a new compressor soon, or trying to figure out a way to get some airflow onto this one (maybe a little fan or something?!?).
Re: OBA setup
« Reply #9 on: February 19, 2015, 03:34:36 PM »
 Jay, take a look at my setup tonight, might give you some ideas.
Re: OBA setup
« Reply #10 on: February 19, 2015, 04:19:45 PM »
I always envisioned mounting my OBA where the spare used to be...any cons as to mounting it there?
ie. exposure to undercarriage stuff ie. mud/water/dirt/dust, etc
Also....is this feasible to do w/ any compressor?  I have a VIAIR300P and I'm guessing the hardware is not the issue; more or less the mounting and electrical are the 2 obstacles I forsee...
Worth the hassle or wait and do it w/ the big air tanks that other guys have...?
EDIT:  compressor http://www.viaircorp.com/300P.html
Re: OBA setup
« Reply #11 on: February 19, 2015, 04:34:07 PM »
i mounted my compressor in the storage area below the cargo area and mounted my tank where the spare goes, i wanted to keep the pump more or less out of the dust/mud/water as much as possible.
Re: OBA setup
« Reply #12 on: February 19, 2015, 04:35:04 PM »
Taking notes, as those were my exact thoughts and I have the same compressor.
Re: OBA setup
« Reply #13 on: February 19, 2015, 04:55:14 PM »
Christian - My first thought on mounting the compressor where the spare goes is that it'll eventually end up submerged, and will take on a lot of road grime and dirt/mud. I still have my spare under the rig and the amount of crap it accumulates is unbelievable. I would imagine a good pump can hold up to this no problem, but this cheap-o harbor freight one is definately not designed for that kind of abuse. I've read that some people make a small shroud out of metal to partially cover it, but that would almost entirely negate the added air-cooling benefits and would still leave it subject to being submerged in a water crossing at some point. Not like we cross a ton of water here in So Cal, but it could happen at some point. This particular harbor freight unit has a switch and fuse mounted right on the body that do not appear to be even the least bit weather tight. :(
This setup should work with pretty much any compressor, as long as it'll fit where you want to put it. This harbor freight unit just happens to fit very well into that little space, and my understanding is that some of the VIAIR units are very similar in size/shape (although I'm not going to claim to be anything close to an expert on that).The electrical shouldn't be a problem at all - just use large enough gauge wiring and use a relay if necessary (almost always going to need the relay, unless you run heavy gauge wiring into the cabin and use a 30+ amp switch). And the brass hardware and fittings are all contained within the air lines, so that will also work with any compressor.
Jordan - do you have an issues with the unit cooling in that storage area? Just curious, as that's easily as confined as where I mounted mine.
« Last Edit: February 19, 2015, 04:58:07 PM by JFanaselle »
« Reply #14 on: February 19, 2015, 05:49:55 PM »
Well both the puma and the ob2 compressors have integrated fans, I also had a few(12) 120mm fans left over from various computers so I mounted 2 of those to feed "fresh" air into the compartment from the cabin.
I never tested the temp but it didn't seem to get any warmer from my calibrated touch :)
