Author Topic: Costco: Batteries (and other questions!)  (Read 27899 times)
« Reply #30 on: January 29, 2015, 11:58:50 PM »
Mojave does horrible, horrible things to our rigs.
« Reply #31 on: January 30, 2015, 08:16:12 AM »
x2
Re: Costco: Batteries (and other questions!)
« Reply #32 on: January 30, 2015, 10:29:04 AM »
http://imagizer.imageshack.us/v2/800x600q90/910/m4LJRu.jpg
One of your issues might have been poor charging/contact.  Those battery terminals are pretty furry Steve...might have sprouted a gremlin.  :D
x2
Most...seem...to be...self...inflicted.  ;)
« Last Edit: January 30, 2015, 10:31:21 AM by GhostX »
« Reply #33 on: January 30, 2015, 11:48:32 AM »
Believe it or not John, it use to be much worse!
Jordan helped me clean the terminals and install those felt circles between the battery and terminals.
How do I go about changing the terminals?
« Reply #34 on: January 30, 2015, 12:12:34 PM »
yes, steve also sprayed the terminals with the red spray to combat the furries from returning, looks like it didnt help completely.
replacement terminals for ya steve, http://www.amazon.com/Shoreline-Marine-Battery-Terminal-Kit/dp/B004LR5K30
« Reply #35 on: January 30, 2015, 02:42:34 PM »
Well, in all honesty....one side mirror and a tire blown after racing through some of that desert terrain....I'm feelin pretty lucky all in all
« Reply #36 on: January 31, 2015, 12:55:32 AM »
I forgot about the mirror, that was a lucky one
« Reply #37 on: January 31, 2015, 04:56:21 AM »
Steve how old is that battery?   It looks a lot like the terminals on an old battery I had on another vehicle that was leaking.
So you could replace the fusible link on the positive.  http://www.amazon.com/Genuine-Nissan-Battery-Fusible-24380-79915/dp/B00F66O6B2/ref=pd_sim_sbs_auto_1?ie=UTF8&refRID=0E6KCBAA68DQ1KX994J1
And you could cut off the negative terminal and solder/crimp a new terminal on it.
And I would say a new battery(preferably a sealed gel/agm) is definitely in your near future.  While you are changing it out definitely take some a strong base solution(Baking soda and water) to the box and hold-down.   Then use the felt washers and "red stuff" and see what happens.
« Reply #38 on: January 31, 2015, 12:55:31 PM »
No need to replace the fusable link, the stock terminal attaches with a bolt and nut similar to what the marine terminals I linked to have, you would just need to cut off the negative and have a ring terminal crimped on to attach to the negative post clamp.
« Reply #39 on: January 31, 2015, 06:49:27 PM »
It just looked like the corrosion completely covered the fusible link.   I think what $26.00 would be a cheap price to pay if you are going to do it.   Then would have a trail spare.
