Author Topic: Lifting questions  (Read 14772 times)
Lifting questions
« on: May 10, 2013, 09:59:08 AM »
Heyoooo!!!
Ok guys and gals....please chime in on what you think/what your experience has been...
I'm looking to lift my rig a little....say, 2-3in......I'd like her to be just a bit taller for a little more articulation and also more clearance for when I get new tires, I'm moving up a size from 265 to 285 when my current shoes run out
Now, I will have new UCA's in my possession next week <Total Chaos>, and I have the Bil's 5100's up front, and I have Ghost's rear Bils still in the box for the rear-end..
I'm looking at two different lifts...
PRG- http://www.prgproducts.com/shop/product/prg-2xe31mk-x/
NISSTEC-  http://nissteclifts.com/index.php?page=shop.product_details&flypage=flypage.tpl&product_id=58955&category_id=173&option=com_virtuemart&Itemid=72
**PLEASE DO NOT GET INTO THE WHOLE PRG VS. NISSTEC DEBATE....THAT'S WHY THIS IS POSTED HERE ON SCCX RATHER THAN TNX....**
Anyway....names aside, is there a difference between the two?  One that looks/feels/works better than the other?  Anyone rocking one or the other and have any tips/thoughts?  Any materials I might need on top of what it comes with?
Thanks in advance for any and all advice!!!  :)
(p.s. feel free to move this to another forum if so desired)
BikersCage
Re: Lifting questions
« Reply #1 on: May 10, 2013, 03:32:20 PM »
Doing UCA dont forget the bolt if you are going to cut it out. If you buy it from a dealership its 15 right away.
Plus CAM bolts will be required with a lift.  If you do not already have them.
Re: Re: Lifting questions
« Reply #2 on: May 10, 2013, 07:04:56 PM »
If articulations what your after, spacers won't help that up front. You'll have the same travel just moved down in the range of available wheel travel, less stuffage.
I know you have aftermarket wheels that stick out further than stock, how close are the current tires to the fender when turned? The 285 will be a half inch closer in a perfect world, in the real world it will depend on the tire you end up going with.  The lift won't really help with clearance of tires, cutting does :-) it will look badass though.
What do you currently have? 5100 up front and shackles rear? Whats your ideal amount of lift total front and rear? What are the 5100's set to lift wise?  Too lazy to look at your "build" thread :-P  I ask because my experience with them was they ride harsh when set 1.5" or higher. Might I suggest a 3" spacer would allow you to run 1" lower setting on the bils for a better ride.
Also best way to improve front end articulation is to disconnect your front swaybar on one side when you wheel.  Takes 2 mins, easy to do while airing down.
Sent using Al Gore's internet
« Reply #3 on: May 11, 2013, 07:00:44 AM »
That's a really good idea Jordan!! The more articulation, the better.
Have you done this before?
Is there a lot of rattling when you disconnect the sway bar on one side?
Is the loose sway pretty stable, or do you run the risk of catching it on something?
Thanks for the tip
« Last Edit: May 11, 2013, 07:02:24 AM by HEVAK »
« Reply #4 on: May 11, 2013, 08:24:33 AM »
Sorry to hear about that debate.  They all work the same.  Calmini also has great products, just not great customer service.  It should always come down to personal preferance and budget.  For most of the trails we do, you don't need a whole lot of articulation.  Personally, I have never had to disconnect the front sway bar.  Do ditch the rear one though.
« Reply #5 on: May 11, 2013, 08:43:32 AM »
Disconnecting one side keeps the sway bar under control so it wont go anywhere and the ride is night and day difference.  Much better ride. I've noticed my truck handles bumps and off camber stuff much better.
Fwiw I noticed the same effect on my first gen, and while not needed, its free and takes 5 mins and allows the suspension to work independently.
« Reply #6 on: May 11, 2013, 09:32:49 AM »
I'll definitely try it the next time we do a heavier trail.
Thanks
« Reply #7 on: May 11, 2013, 10:14:05 AM »
I have no true 'lift' right now; the only real lift my truck has is due to the Bils being maxed out; maybe that's what I'll do is get the 3in spacers and then be able to allow the shocks to absorb better...
I get plenty of rubbing pulling into parking spots, driveway, etc....so the melt mod is high on my list....
I have 5100's up front....don't think I have any 'lift' per-se in the rear....
Is this with ANY UCA?  I have all new bushings (I was told I'd need them), but new CAM bolts?....
I'm down to try the sway bar trick as well...thanks for the tip Jordan and lemme know when you wanna put that bumper on....I'm happy to help!
« Reply #8 on: May 11, 2013, 11:33:59 AM »
Bumper!?!? What did you get Jordan?
« Reply #9 on: May 11, 2013, 05:26:28 PM »
Ray, I ordered a hefty zombie edition.  9 to 12 weeks.
So you have the 5100 maxed out at 2.5" ? Thats more than likely compensating for the weight of the front bumper than providing actual lift, and a harsh ride to boot.  I would honestly save your dollas up and get some radflos or an emu setup, with how you drive you would appreciate them. ;-) your nickname from Mojave is Christian "Ironman" Stewart err Sorensen.
if you want 3" of lift in the back, an aal and shackles should work out for you.
If you already rub with those wheels and 32" tires, cutting the pinch weld behind the fender liner might be required.  Pretty easy and quick with a grinder/sawzall.
« Reply #10 on: May 11, 2013, 05:36:47 PM »
The UCA bolt is not realy an issue, loosening the steering to allow removal of the bolt is not that hard.  And if you have camber bolts you don't need new ones, but only 05 xterras came from the factory with ones and if you truck never had an alignment issue then you might not have them.  Easy way to check is to look at the lower control arm bolts and look at the washers, if they are offset then you have camber bolts, if they are centered then you will most likely need camber bolts. New UCA will come with new bushings so that's not an issue.
« Reply #11 on: May 11, 2013, 08:18:24 PM »
If I remember correctly, there was a Night Armor PRO 4X hanging with me on Soda Lake ;)
And I now have to price out shackles and AAL.....and new Radflo's.... ;D :D :D ;D ;D ;) ;) ;) ;)
chrishaynesusa
  • thenewx
  • 4wd Pts: -36
« Reply #12 on: May 11, 2013, 08:31:53 PM »
someday with your front swaybar disconnected your going to hit something and bend the sh!t out of the sway bar.
then it wont go back on right and it will be a bi!tch to get off because it's bent.
do or do not.
« Reply #13 on: May 11, 2013, 09:20:35 PM »
NICE!!!! That bumper is SICK
KickinTires
  • 4wd Pts: 9
« Reply #14 on: May 11, 2013, 10:02:59 PM »
Greg at PRG is working on a cable activated sway bar disconnect that appears to mount in the middle of the sway bar.  Not really sure how well it's going to work but I would imagine that Greg will get it right before it goes on the market.  If you're on FB, he put up a photo of it a while back...
Mark
Club Frontier Member "KickinTires"
