User name: Toro
Year: 2006
Trim: S Auto
Color: Black
Mods:
Drive train
-M226 diff swap with e-lock
-M226 3.13 regeared to 3.73 by Tri-County in Pomona with custom CNC'd spacer
-3.69 R180 w/ ARB air locker
Suspension
-Prg RadFlo 2.5 coilovers
-Prg UCA's
-Prg Adjustable Shackles
-Prg Adjustable Cam Bolts
-Prg RadFlo 2.0 ext res rears
-Rear Dakar HD pack
-Sway bars removed
-2" JP body lift
All sitting on 35" BFG KO2's
Rear Diff....
Rear spring perches were cut off and the diff was rotated for better driveline angles. Diff shock mounts were removed, boxed and raised up out of the way. Upper mounts were redone and raised to offset the lowers and strengthen. Rear right shock relocated to rear of diff to avoid oncoming hits.....again.....
Armor
-KMA front bumper with Lo Pro light bar
-Hefty rear bumper w/ dual swing arms holding spare, hi-lift and 10 gallons of fuel
Thanks SteveC!
-Full Hefty Skids
-The first ever White Knuckle sliders
-Custom raised, boxed and reinforced rear shock mounts.
-Shrock Works diff skid (Non Purple edition)
Thanks Mr. ChrisHaynesUSA
Lighting
-40" 4D all spot beam curved bar
-5" KC HID's in bumper
-HID head lights
Recovery
-Engo 12k winch with synthetic line
-Hi-Lift Xtreme
-Off Road Base
-30ft tow strap
-shackles
-maxtrax boards
Electrical
-RuggedRocks 180amp alternator
-65 series AGM primary battery
-34 series AGM battery mounted in OE spare location
-National Luna dual battery charge controler w/ in cab remote all linked in w 0/2 cable.
- one 2/4awg to four 4/8awg AGU fused distribution block under the hood
- ATC 20 slot fuse box wired to constant
- ATC 20 slot fuse box wired to ignition
Almost everything is wired to one of these locations
- 100watt solar panel, charge controller stored under roof rack when traveling or not in use.
On Board Air
-ARB twin pump
-Pump fed by 4awg cable
-One 4awg to two 8awg AGU fuse distribution block
-Custom mount with manifold, pressure gauge and chucks in rear.
-High pressure hose routed to the hood to ARB manifold with locker solenoid and air chuck
Twin 5 gallon tanks are coming soon. I will be running air tools on the trail.
Switches
-VDC switch relocated to left of steering wheel
-OTRATTW switches down low running the diffs
-Home brew over head switch panel for all rooftop lights
Cargo, Camping, Overland
-Frontrunner Outfitters full replacement aluminum roof rack.
-Home brew cargo area carrier shelf.
-Frontrunner Outfitters 13 gallon wedge water tank behind rear seats accessible by a hose by the rear passage seat.
-ARB 6foot awning on driver side.
-Edgestar 43qt refrigerator donated by the one and only ChisHaynes and brought back from the dead by yours truly.
-Home brew fridge mount with slide out.
-Airflow Snorkel
Comms
-Kenwood TMV-71A Ham Radio
-Uniden 520XL CB radio
-Wilson Little Wil Ant.
-NMO Mag Mount
-One load mo-fo PA speaker to talk isht through.
(cell phone useres, hikers and Geocachers
![Wink ;)](https://www.sccxterra.com/smf/Smileys/akyhne/wink.gif)
Audio
-Pioneer head
-Alpine speakers
Comments:
Registered here a looooooong time ago and never became active on the site. Re-registered here a few years ago and have become more active. I have been fortunate and have benifited from the generosity of many.
A very special thanks to
-John at Whitknuckleoffroad for making the best sliders ever for our rigs
-Steve at Frontrunner outfitters for producing a stellar aluminum roof rack for our rigs.
-Steevo at RuggedRocks for offering the best customer service and simply being bad ass.
-ChrisHaynes, SoCalX, SteveC, MotoPig77 for the crazy awesome hook ups!
As our family grows, this rig has gone from mini rock crawler to to full on Expo/Overland rig. We love bugging out and setting up camp in the middle of no where.
![](http://uploads.tapatalk-cdn.com/20161230/27a969ab7fb63d38198e605f8c1c00cf.jpg)
![](http://uploads.tapatalk-cdn.com/20161230/a6810fc39aaa58e3402aef60410b3b68.jpg)
![http://uploads.tapatalk-cdn.com/20161230/ad6df5602c69e415cdc54d92280c8aab.jpg](http://uploads.tapatalk-cdn.com/20161230/ad6df5602c69e415cdc54d92280c8aab.jpg)
El Toro, let me introduce you
![](http://uploads.tapatalk-cdn.com/20161230/e3a0dab36eda56a3d8b6b2646769941e.jpg)
![](http://uploads.tapatalk-cdn.com/20161230/592f754b72649504eecb686edec7bfb2.jpg)
![](http://uploads.tapatalk-cdn.com/20161230/53d4d8d1fbe9a4992b97583e39f30e32.jpg)
![](http://uploads.tapatalk-cdn.com/20161230/00e76ee887a2c11789b637edc0982f02.jpg)
Toro's my rig, I'm Danny
