Author Topic: Anyone want to help a San Diegan with his lift install in mid November  (Read 25359 times)
hunter0389
Re: Anyone want to help a San Diegan with his lift install in mid November
« Reply #45 on: November 11, 2012, 05:22:35 PM »
Sweet.  How high are the front and rear?  Looks like it is leveled.
« Last Edit: November 11, 2012, 05:54:41 PM by hunter0389 »
2007 Solar Yellow
« Reply #46 on: November 11, 2012, 05:26:44 PM »
Definitely higher in the front, gotta crank them suckers down.
InsideOut104
« Reply #47 on: November 11, 2012, 09:48:13 PM »
I didn't take measurements. It is higher in front for sure! The coilovers gotta go down. Probably about an inch!
« Reply #48 on: November 11, 2012, 11:18:55 PM »
Lift looks great.  Assuming you are running 16" wheels?  I agree with Jordan...let some tension out of the coils.  That is unless you plan on adding weight (armor, sliders, winch) in the near future.
InsideOut104
« Reply #49 on: November 12, 2012, 08:17:55 AM »
No, these wheels are the stock 17's (SE model). I am hoping someone in or near Long Beach can help me after work this week to lower the CO's a little bit. Anyone in or near Long Beach area?
I only plan to add sliders, and stock Off Road/Pro4x skids.
« Reply #50 on: November 12, 2012, 08:22:55 AM »
Definitely let some tension out then if those are 17's. That should help the CBC.
InsideOut104
« Reply #51 on: November 12, 2012, 10:49:11 AM »
I'm not exactly sure it's CBC. It isn't metal to metal. From what I can tell, it is the bump stops on the UCA's hitting the coil bucket. The only "clunk" noise I can hear is coming from the passenger side. I should have brought my tools with me to Long Beach so I can triple check everything was tightened up (we double checked before putting the wheels back on already).
