May 23, 2012, 08:24:56 AM *
Pages: 1 [2]
Author Topic: Bandit4x4 IA Bushings, LCAs  (Read 1089 times)
RockinX
« Reply #15 on: May 04, 2011, 08:42:25 AM »
I just had mine welded and it's holding up fine.
And you had them welded without taking them off. Nice!  Thank you for the info Mitch.
Soylent Yellow
« Reply #16 on: May 04, 2011, 08:58:08 PM »
Only the driver's side.
Pigcat
« Reply #17 on: May 04, 2011, 09:21:11 PM »
I had cracks in my driver's side welded also.  It was holding up fine but I ended up replacing both LCAs after bending the passenger side in Sedona - hit a boulder pretty hard while trying to avoid a cattle guard  Cry  You've had your rig for a long time so the ball joints are probably ready for replacement anyways, so it may be best to go ahead and get new LCAs.  I bought mine from Courtesy Parts - saved about $100 off each and shipping cost was around $25.  I had the shop weld up some reinforcements around the shock mounts before install.
Tom
Tom
When in doubt - Gas it out
RockinX
« Reply #18 on: May 04, 2011, 10:38:40 PM »
Yeah, you really have to watch out for those cattle guards.    I wouldn't have been surprised if you had said you had welded up just about every part possible on your X.  You are definitely not shy about challenging obstacles!
I was quoted $500 for the labor from my mechanic for the one side and today they said they could do both for that price.  Since there is no guaranty that the $50 weld job is going to hold and because of the new ball joints and bushings you and Bobby mentioned, I think I will go ahead and get the new LCAs from Courtesy Parts.  And it only makes sense to have a reinforcement plate done at the same time.  Now I need to do some research to find someone that will do both.
Update:  I talked to my muffler guy and he said he doesn't weld structural parts.  But when he looked at the cracks, he said no problem since they were not that significant.  I may do that as a bandaid until after Big Bear and then get it taken care of permanently.  Might be time to get a new Flowmaster.   Grin
« Last Edit: May 06, 2011, 02:21:12 PM by RockinX » Logged
Pages: 1 [2]
