May 23, 2012, 06:34:21 AM *
Author Topic: How-to: Bushings Shot? Maybe Not!  (Read 711 times)
Oz
« on: February 05, 2011, 03:54:55 PM »
I've had a nasty clunking when backing up or rolling forward slowly. Really noisy when turning. When the weight of the truck would shift there would be a resounding "clunk". When SQB was here on the Hungry Valley run he noticed it right off and suggested it was the wheel bearings (due to having spacers). Well checked the wheel bearings and all good. Tightened down everything on the front and clunk still there. Had a 4WD shop diagnose it and showed me the movement of the LCAs when stopping and reversing. They thought the LCAs needed the bushings replaced. Sounds reasonable. Enter Greg at PRG products. I will say this quite emphatically. A CALL TO GREG MAY SAVE YOU A COUPLE OF HUNDRED BUCKS!
Greg surmised that it may not be the bushings. He says in fact that they should last a long time (much longer that the 36k on my X). He said that historically the front and rear sides of the 'fork' on the LCAs have a rubber 'washer' that wears easily. PRG Products] has in fact a product that cures this problem. Delron inserts that go on each side of the 'fork'. Here's a "How To":
As always, safety first. Chock your wheels
A quick spray of WD to make the nuts come off easier
AS to not screw with the alignment too much I marked the position of the camber bolts and washer. I will have it aligned next week but this will get me by.
Now here is the exposed 'suspect' bushing. Doesn't look too bad!
Here's a brand new one from my Titan LCAs. Compared to this the old one looks OK
Round, like lifesavers. Delron washers/spacers from PRG Products
Here's what the busing looks like without the Delron spacer
Here's with the spacer
"Fork" end of LCA sliding in with Delron spacer.
Before tightening nuts I like to use a little anti-seize grease. This would be especially good advice for all you snow bound salt road guys.
Washer and bolts line up to original postion.
On this job I used my floor jack to manuever the LCA around. Taking the pressure off makes its a ton easier to get them bolts off. I did not have to beat them on or off. Came out with a simple pull.
Then tighten everything back up. Lather, rinse, repeat for the other three bolts you'll have to do.
All done! No more clunk!!!
« Last Edit: February 05, 2011, 03:59:52 PM by Oz » Logged
Ruination Fan
« Reply #1 on: February 05, 2011, 05:54:35 PM »
Pretty cool, Greg does know his stuff. Nissan probably didnt put 285 series tires and spacers into the R&D of the second gen  Wink Good thing Greg decided to swing over to the Nissan side from the old I-Beam ways he was known for before.
« Reply #2 on: February 05, 2011, 05:59:43 PM »
Good deal.  Those bushings are a beast to remove, at least on the first gens.
GhostX
Old School
« Reply #3 on: February 09, 2011, 03:25:50 PM »
Nice carpet Oz!
Berber?  Grin
ARB Rear Locker ~ Fully Shrocked ~ PRG 4WD Kit ~ Radflo 2.0's ~ BFG KM2's ~ Xoskel Light Cage ~ KC Daylighters ~ KD6DCI
AV Xterra
« Reply #4 on: February 09, 2011, 06:46:01 PM »
Mmmmm.. Berberrrrr...
Oz
« Reply #5 on: February 10, 2011, 07:26:13 AM »
Nice carpet Oz!
Berber?  Grin
Ah hah, nah simulated berber
When I was single this was a cheapo area rug from Lowes. When I got married my wife quickly banished it to the garage for some reason Smiley
