May 23, 2012, 06:18:01 AM *
Author Topic: Drive Belts  (Read 771 times)
chad
« on: January 08, 2011, 12:57:03 PM »
Does anyone know where i could get a write up on how to replace the driving belts (not the timing belt) on a 2000 xterra?
« Reply #1 on: January 08, 2011, 01:22:30 PM »
Sent the factory service manual chapter on this to the email addy in your profile.
chad
« Reply #2 on: January 08, 2011, 04:34:33 PM »
Thanks for the paper work
Now I've never done this before!!!!
so do i first adjust the Idler Puller bolt to loosen then remove the belt?
« Last Edit: January 08, 2011, 04:41:30 PM by chad » Logged
« Reply #3 on: January 08, 2011, 05:28:18 PM »
Depending on the belt, maybe; kind of depends on exactly which one to which you're referring.
Typically the bolt in the center of the pulley fastens it; it must be loose before going after the tensioning bolt.
chad
« Reply #4 on: January 08, 2011, 05:37:05 PM »
I'm doing all three and changing the pulley. unless someone thinks i shouldn't.
I am also installing a new thermostat (X is starting to overheat)
chad
« Reply #5 on: January 08, 2011, 05:57:29 PM »
first i loosen this
Drive Belts
chad
« Reply #6 on: January 08, 2011, 06:00:14 PM »
then i adjust this
Drive Belts
« Reply #7 on: January 08, 2011, 06:09:55 PM »
Correct.
Unless the idler pulley bearing is making noise, it doesn't need to be replaced.  You also can track down a bearing for $10 instead of paying lots more bucks for an entire assembly.
chad
« Reply #8 on: January 08, 2011, 06:29:14 PM »
I already bought all the parts so it's all getting replaced. Unless you think I shouldn't
chad
« Reply #9 on: January 10, 2011, 10:57:40 PM »
Hi Bobby was unable to change the belts this weekend my little girl was sick.
I should be able to get it done this weekend
thanks for the info.
chad
« Reply #10 on: January 24, 2011, 11:02:50 PM »
Hey thanks for the help and info got the belts on no problem
How long should i wait before I readjust the tention?
« Reply #11 on: January 26, 2011, 09:30:47 PM »
If they are adjusted properly they won't require any re-tensioning.
