Greetings,
Had the timing belt (water pump, belts, tensioner, thermostat, hoses etc) installed. Drove truck about 20 miles and started hearing a loud "tick tick tick". On way back to shop, the truck lost all power. Engine would start but no power, rpm etc. Similar to when the air intake gets separated from motor. Had truck towed to shop. Initial thought from shop is the "belt slipped a tooth"
If the belt is slipping or not attached isn't that the same as having it break? Shop said no
They're going to tear it down to try and find out what's up. Question to you all - is the motor fried? What are your thoughts? I don't have much faith in having the shop try and rebuild the motor if its toast. If motor is gone, do you think I can demand that they have it towed to dealer to be repaired at the shop's cost?
Thanks.
Tom
