February 05, 2012, 12:39:27 AM *
Author Topic: Help - how does this go back together!  (Read 664 times)
Summer, Paul, and Noon
« on: May 11, 2010, 06:08:28 PM »
So I replaced a broken strut tonight (see Suspension forum thread) and found my skid plate full of oil. Looking above it the drive shaft has come out of the front differential. It looks like there's a seal that gave way exposing the oil leak. The tire spins freely at this point and the shaft doesn't go back that 2-3" that it looks like it needs.
How does this go back together? Is this a job I can do or does it need to go to the dealer? Can the vehicle be driven in 2WD to get there? What's involved?
http://i6.photobucket.com/albums/y215/paul1960/Xterra/Broken%20Strut/BrokeHalfShaftOne.jpg
http://i6.photobucket.com/albums/y215/paul1960/Xterra/Broken%20Strut/BrokeHalfShaftTwo.jpg
http://i6.photobucket.com/albums/y215/paul1960/Xterra/Broken%20Strut/BrokeHalfShaftThree.jpg
2006 Xterra Off Road
« Reply #1 on: May 11, 2010, 08:11:37 PM »
Done - apparently you just wiggle it around and spin the wheel and it pops back into place.
Oz
« Reply #2 on: May 12, 2010, 05:36:06 AM »
Paul did you mean Drive shaft or Axleshaft coming out of the Dif - dont see the DS in your pix
Shaka Brah \m/
« Reply #3 on: May 12, 2010, 12:49:16 PM »
I'm not sure of the names but it's the axle shaft that comes out of the front differential heading to the starboard side into the wheel. Theres a seal that seems to have popped out of place. Picuture two above shows the gap exposed, its back together again now.
Oz
« Reply #4 on: May 12, 2010, 07:54:46 PM »
Ah ok - was a little confused cause the DS (or if your in England they call it a 'propeller shaft') runs from the transfer case to the dif. Ya the axle shafts run from the dif to the wheels - they both can pop out - but different ways to address the, BUT you figured it out so this is rather moot now  Smiley
Shaka Brah \m/
