May 22, 2012, 10:04:08 PM *
Pages: [1]
Author Topic: Fluctuating idle - Any tricks to cleaning the mass air flow sensor?  (Read 584 times)
Pigcat
Newbie
« on: April 14, 2010, 03:59:51 PM »
Greetings,
My idle sometimes slightly increases and then seems to fluctuate between the 750 - 850 rpm spot.  I was thinking it may be the MAF.  I remember seeing a "How to" post on XOC about cleaning it but I didn't have any luck with the search.  Anyone have any tricks / suggestions etc. for cleaning the MAF or any other thoughts on what would cause the idle to fluctuate?
Thanks.
Tom
Tom
When in doubt - Gas it out
Bobby B.
BOD
Sr. Member
View Profile
« Reply #1 on: April 14, 2010, 06:45:28 PM »
Go to Pep Boys or whatever; there's a spray can of MAF cleaner.  Easier than the q-tip and alcohol bit.  MAF is held in the air intake tube by two Philips head screws.  Remove, spray clean, replace.  Do not overtighten.
There's also a separate sensor near there with two wires.  Pull, give a spritz.  It'll be blue in the middle when clean.
Change the fuel filter, then dump a can of seafoam in the tank before a long drive.
Don't know where you are on plugs, cap and rotor, but if they're old, might be good to do as well.
I like sammiches.  And bacon.  Sammiches with bacon.  And chips.  Lots of chips.
Pigcat
Newbie
« Reply #2 on: April 14, 2010, 09:04:54 PM »
Bobby B still given the tech answers - some things just don't change.  Cool
Thanks.
Tom
Tom
Oz
Sr. Member
Cybernetic organism; living tissue over metal
View Profile WWW Email
« Reply #3 on: April 14, 2010, 09:16:10 PM »
Thanks.
Tom
Hallelujah - having Bobby on this board is a blessing
Pages: [1]
