OK, quik update. Here are pics of the pistons with the SWAIN ceramic coating on the domes (tops) and poly-moly coating on the piston skirts, rod bearings, and main bearing surfaces. These are supposed to attract oil to them and provide a temporary slippery surface to prevent metal-to-metal contact IN THE EVENT OF OIL STARVATION, like rock crawling or something like that. Also extends the oil change interval from every 3000 miles to 7500 miles and extends the overall life of the motor by adding an additional 150,000 miles to the engines life.
02/14/10 Transfer case question and a Motor rebuild update
irwinsPicture3 009.jpg (598.24 KB. 1280x960 - viewed 253 times.)
irwinsPicture3 010.jpg (494.61 KB. 1280x960 - viewed 265 times.)
irwinsPicture4 012.jpg (547.01 KB. 1280x960 - viewed 232 times.)
Also here are some pics of the replacement header from an aftermarket made from CHINA steel. Made thicker which is good but ports on the inside are smaller and cast is much, much more rough on the inside. A port and polish is an absolute must for these pieces.
irwinsPicture4 001.jpg (606.87 KB. 1280x960 - viewed 236 times.)
irwinsPicture4 006.jpg (541.66 KB. 1280x960 - viewed 235 times.)
Here are closeups of the rough casts on the inside.
irwinsPicture4 002.jpg (608.11 KB. 1280x960 - viewed 147 times.)
irwinsPicture4 003.jpg (552.17 KB. 1280x960 - viewed 145 times.)
These are the results after the ports have been cleaned up.
irwinsPicture4 005.jpg (615.24 KB. 1280x960 - viewed 146 times.)
irwinsPicture4 004.jpg (543.78 KB. 1280x960 - viewed 152 times.)
