May 22, 2012, 05:44:42 AM *
Author Topic: Need help with a pml  (Read 1742 times)
chad
« on: April 09, 2009, 12:29:28 PM »
I’m about to do a pml to my 2000X what are the torque specifications for the shackles front shocks and rear shocks
chad
« Reply #1 on: April 10, 2009, 12:19:43 PM »
OK guys today is the day I will finaly tackel this job I have all the parts and if all goes well I will finaly have my lift
Goldfish
« Reply #2 on: April 10, 2009, 01:56:37 PM »
Good luck Chad. Take some before and after pics.
Don
chad
« Reply #3 on: April 10, 2009, 09:25:39 PM »
 I JUST INSTALLED FROUNT SHOCKS AND A STEARING STABALIZER ON MY X all by myself Grin
wasn't that difficult but the pasenger side that that was apita
ran out of daylight I should be able to install the rear shocks, shackel and twist the t-bars tomorrow
One question
the passenger side of my car is a half inch higher than my drivers side
what do i do?HuhHuh
i'm am going off the assumtion that I correct for it when i twist the t-bars?
« Last Edit: April 11, 2009, 11:52:39 AM by chad » Logged
« Reply #4 on: April 11, 2009, 08:56:30 PM »
It's speeled St-E-E-ring stabilizer.  As for the heigt, don't worry about the difference.  When you PML the front, you WILL have to raise, lower, and measure the height SEVERAL TIMES TO GET IT RIGHT.
chad
« Reply #5 on: April 12, 2009, 03:43:05 PM »
I got the rear shocks and shackles on
Just to let you guys know nobody told me I had to charge the camera battery
I was able to get some pics
All that’s left is to buy a 19mm wrench (thought I had the correct wrench) and twist the t-bars
Correction i found the the wrench
OK everyone the pml is done
Took me a while but it’s all done  Grin
I don’t have many pics because I forgot to charge the battery
I had a problem with the passenger side t-bar, that bolt under the lock nut that was supposed to be bolted to the cross bar wasn’t. Took me a few turns and measurements to figure it out, had to hold it with the wrench as I turned the adjustment bolt all went smoothly after that. Then I had to hold the adjustment bolt as I twisted that nut down and then the lock nut. I hoped I did it correctly Huh
Well all in all it wasn’t that difficult, a bit scary but I managed to do it. It rides a bit on the bouncy side.
Going for a test run Grin and them heading off to get my front end aligned.
let you guys know how it runs
« Last Edit: April 13, 2009, 08:36:19 AM by chad » Logged
