May 22, 2012, 04:46:50 AM *
Author Topic: Engine Grounding*****superslide*****  (Read 1391 times)
At2Fleury fleury123
« on: February 09, 2009, 10:28:11 PM »
I am hopimg to get superslide to post up some pictures of where he mounted his grounding wires . I am interested in following his lead on this.
« Reply #1 on: February 12, 2009, 05:59:42 PM »
Here is one pic.  I'm working on getting more.  Patience young padowan...
This picture shows the cable to the top of the throttle body and another on the left top side of the plenum where some wires escape the wiring harness to ground.  It's on one of those ground wires where you want to attach the larger ground wire to the frame.  I later moved it a bit farther back and added another towards the front.
* Irwins-pics_145.jpg (1295.79 KB. 2048x1536 - viewed 236 times.)
* Irwins-pics_144.jpg (1264.64 KB. 2048x1536 - viewed 207 times.)
In this picture below, there is a grounding point on the top of the throttle body and another one below the underside of throttle body cable barcket.  There is a third one from the AC pump bracket to the driverside frame.
* Irwins-pics_146.jpg (1321.69 KB. 2048x1536 - viewed 215 times.)
« Last Edit: February 12, 2009, 06:10:43 PM by superslidestyle » Logged
« Reply #2 on: February 12, 2009, 06:18:24 PM »
* Irwins-pics_420.jpg (549.63 KB. 1280x960 - viewed 212 times.)
* Irwins-pics_418.jpg (601.85 KB. 1280x960 - viewed 201 times.)
« Last Edit: February 12, 2009, 06:27:02 PM by superslidestyle » Logged
xperienced
Glamis wall ride- all stock
View Profile WWW
« Reply #3 on: February 13, 2009, 03:31:28 PM »
What's the advantage of improving the grounding?  I just grounded some offroad lights directly from the battery.
At2Fleury fleury123
« Reply #4 on: February 13, 2009, 09:58:37 PM »
better conductivity for starters, which means no electircal spikes to the computer. In theory better efficiency and more power but I dont think much. I also read some stuff about creating better injector spray patterns, but I am not sure.
« Reply #5 on: February 16, 2009, 07:06:33 PM »
I't's mainly to lower the electrical resistance on the motor which allows the spark plugs to fire off a faster rate when revving up high and you only pick up about 1 hp, but about 4-5 lbs. of torque.  It also allows other electrical components to work more efficiently.  Things like lights you can ground to the battery or to the frame as long as its a good clean, metal to metal contact.
