May 21, 2012, 02:15:41 PM *
Pages: [1]
Author Topic: ?? on Sway-bars...  (Read 1913 times)
superslidestyle
Hero Member
Are we ready? Not really but here we go!
View Profile WWW Email
« on: January 01, 2009, 05:04:50 PM »
for off-road purposes, trail runs, etc., do we disconnect/remove the sway bars or leave them on?
WQKD768
2000 Xterra XE V6 4WD
2007 Murano SE AWD V6
chad
Full Member
View Profile
« Reply #1 on: January 01, 2009, 06:08:44 PM »
I remember when i first joined the board i was a bit nervice taking a stock vehical out on the trails.
Turns out the X does just fine
remove the mud flaps and runnung boards and you will be fine
If you get stuck someone will pull you out if you alone start time to dig and move rocks around
i am still at stock height and gone up and down hills i would have never thought possible
Its sound like you have the same questions i had and still have
if money is an issue take baby steps
tires
sliders
pml
Hey don't get me wrong or anything, I have been in the outdoors but... is it always this dusty?Huh
BOD
Hero Member
View Profile
« Reply #2 on: January 01, 2009, 06:37:37 PM »
Don't take the front sway bar off.
Bobby B.
BOD
Sr. Member
View Profile
« Reply #3 on: January 02, 2009, 05:53:11 PM »
Remove the rear bar and chuck it; it doesn't really do much.  If you're driving the X fast enough to try and need it, you need to slow down.
Leave the front bar on.  In most cases, we don't have enough travel to warrant removing it and pulling it off dramatically reduces on-road handling.  I tried it once and while it was okay when driving normally, with any weight on the roof it felt like the truck was going to roll.
I like sammiches.  And bacon.  Sammiches with bacon.  And chips.  Lots of chips.
fleury123
Sr. Member
At2Fleury fleury123
« Reply #4 on: January 04, 2009, 08:48:35 PM »
 I second this as I havent had a  Rear Sway for over fours years. I can notice it sometimes when loaded on a curvy road like on the way to Lockwood , but I just slow down. The front is bad news as I found it becomes unstable to drive
superslidestyle
Hero Member
« Reply #5 on: January 05, 2009, 02:15:48 PM »
But do I disconnect the rear for the trail runs or just chuck it altogether?
WQKD768
Soylent Yellow
BOD
Hero Member
View Profile
« Reply #6 on: January 05, 2009, 06:22:07 PM »
What is this "rear antisway bar" of which you speak?   Grin
I'd rather be happy than right any day.
Bobby B.
BOD
Sr. Member
View Profile
« Reply #7 on: January 05, 2009, 06:58:15 PM »
You can remove it entirely.
fleury123
Sr. Member
At2Fleury fleury123
« Reply #8 on: January 06, 2009, 12:14:41 PM »
Mitch in your case the rear anti sway bar is a cane as you are falling appart it seems.
ultrapc40
Full Member
View Profile
« Reply #9 on: January 06, 2009, 11:23:23 PM »
i Don't have any sway bar anymore hehhe Wider is better!
Just like what everone said, take the rear ones off you will not feel too much of a difference.
Pages: [1]
