February 04, 2012, 11:45:15 PM *
Author Topic: 5" lift question  (Read 1754 times)
XterraTroy
SnwBdr0o0
« on: January 01, 2009, 07:42:27 AM »
This year I plan to do a 5" lift on my X. I'm gonna buy the Calmini 5" lift package and order a 5" Radflo Coilover from prg. My truck is completely stock. Other than brake lines, is there anything else i should mod or adjust before I install the lift? I read somewhere about the front differential needing to be dropped. Do you have to do that for a 5" lift?
To Quote the late Colonel Sanders, "I'm too drunk to taste this chicken."
The X
Oz
« Reply #1 on: January 02, 2009, 09:38:02 AM »
The Dif Drop brackets come with the CM kit as well as the longer spindles. YOU WILL NEED a custom modified driveshaft otherwise you will have driveline vibrations which will toast your TC bearings (Happened to Greg at PRG). CM will give you the specs and hand ya over to JE Reel in Pomona. You'll also have to reroute your ABS line as there aren't any longer options.
Shaka Brah \m/
XterraTroy
SnwBdr0o0
« Reply #2 on: January 02, 2009, 10:30:47 AM »
Great, thanks alot. I'll be sure that I do all that when I get the lift done.
The X
jetta01
« Reply #3 on: February 16, 2009, 12:38:25 PM »
So...have you started this lift project yet?  What size tires are you planning on running?
XterraTroy
SnwBdr0o0
« Reply #4 on: March 11, 2009, 03:56:07 AM »
Nah, I haven't started. I'm still in Iraq. Im not sure If im gonna go with a 5" lift from the get go. Im just gonna do spacers and shackles with UCAs and run 255/85/r16s. I'm gonna go with Definity Dakotas.
The X
