May 18, 2012, 09:47:56 AM *
Author Topic: New problem with X  (Read 817 times)
chad
« on: July 23, 2011, 05:38:47 PM »
Okay had a new radiator put in the X
My friend and I replaced the Lower ball joints and new boots on the axils, new brakes and rotated the disks (took use two days).
The new problem I’m having is the old triple naught X is stuttering, as if its not taking in gas
My friend thinks the fuel pump might need to be replaced.
Going to replace the fuel filter first.
What do you guys/gals think?
Summer, Paul, and Noon
« Reply #1 on: July 23, 2011, 08:19:12 PM »
First get an old priest and a young priest ....  Lips sealed
Double check the area's you worked around and make sure you didn't pop a vacuume hose off - similar symptoms and arrise. Under full bright light carefull inspect looking for stray hoses or orphan hose connections.
Changing the fuel filter is always a good thing.
2006 Xterra Off Road
Ruination Fan
« Reply #2 on: July 23, 2011, 08:39:03 PM »
X2 on Vac. hose. Also, try the filter first before you condem the pump (I am a fan with going with the cheaper stuff first  Wink ).
« Reply #3 on: July 24, 2011, 01:01:56 PM »
Also check the rubber air inlet.  If that thing splits and sucks air beyond the MAF, you'll get a stumble.
chad
« Reply #4 on: July 24, 2011, 01:36:07 PM »
Thanks we will be getting under there Monday
My X is a 2000
We Already looked for vac. leaks and such.
My kids miss the bumpy roads.
Once this gets fixed I will be in the market for some new tires and then I'll see you guys/gals on the trails.
Ruination Fan
« Reply #5 on: July 26, 2011, 08:50:13 PM »
Any luck?
chad
« Reply #6 on: July 26, 2011, 11:08:44 PM »
Not yet
Won’t be able to work on it till Thursday or Friday.
I’m on summer break now so being without a car isn’t that bad.
chad
« Reply #7 on: July 31, 2011, 03:36:08 PM »
The X is now running well Grin
All I need now is tires, alinement and a dirt road.
I should be ready by this weekend.
Soylent Yellow
« Reply #8 on: August 03, 2011, 06:59:58 AM »
What was wrong with it?
chad
« Reply #9 on: August 13, 2011, 09:35:40 PM »
The solenoid went out.
Replaced it and all is working fine now
I am thinking of hitting Big Bear Sunday to test out all my new parts.
« Reply #10 on: August 16, 2011, 10:25:13 AM »
Ha ha ha!  Old priest and young priest huh?!  Haven'T heard that one in a while.  Make sure you change the fuel strainer that is attached to the fuel pump inside the gas tank once a year.  Otherwise you'll kill the fuel pump.
chad
« Reply #11 on: August 16, 2011, 02:50:55 PM »
After replacing both ball joints, cv boots, brake lines, radiator, thermostat, other stuff I cant remember, and new tires I decided to give her a test drive. Drove to Big Bear last weekend and took out for a spin nothing fell off so I guess we did everything correct Grin
